Im in the market for a new build but am on an incredibly tight budget. Looking to take my current machine and repurpose it as a light gaming / 'family room' machine. Would also like to take my current 550w PSU and use it in the new build to save some money if at all possible.
Given its age and the fact that its had an almost 24/7 uptime (even if typically not heavily loaded), im a little hesitant to stick it into a completely new build.. especially considering that i know it works perfectly in my current setup. Funds are very tight but im trying to build a machine that will last about 5 years. Not sure if i should expect another 5 years out of it.
New system build using old 550w power supply. Would Preferably have a new / quality 550-650w in it but thats impossible to do for ~$50 as far as i know.
Power - Corsair 550w - CMPSU-550VX (http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004) (Purchased Feb 2009)
Processor - Intel Core i5-4670 Haswell 3.4GHz LGA 1150 84W Quad
Video - AMD XFX 7850 2GB (in current build)
MB - Unchosen Motherboard (Still trying to find a good all-in-one fit)
Ram - Unchosen 8GB (possible 16gb later)
HDD1 - 2TB WD Black
HDD2 - Misc SATA HDD
HDD3 - Misc SATA HDD
DVD-RW
Multiple case fans
Old system with a new and inexpensive 430w power supply. Also likely needs a new case. A case + PSU that would service this build for under $50 would be nice, but probably a pipe dream, still looking.
Power - CORSAIR CX430 (http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026) $40 - $20 rebate
Intel Q9400 2.66ghz
Video - ATI X1900 512mb
MB - Gigabyte GA-EP45-UD3R
Ram - 4gb Corsair CM2X2048 - XMS2-6400
HDD1 - 250gb IDE HDD
DVD-Drive
CD-RW Drive
(The spare case this setup would go into has no case fans aside from PSU fan. Its very iffy if thats going to work but theres is a slight possibility. A replacement case would be ideal bit dont think that will fit the budget if i need a new PSU for the new build as well.)
Suspect that im simply trying to do too much with too little budget here and might be setting myself up for trouble. Any thoughts you guys have would be appreciated.
HDD1 - 2TB WD Black
DVD-RW
Multiple case fans
Intel Q9400 2.66ghz
DVD-Drive
CD-RW Drive
