Multiple Orthos Failures 33+ Minutes into test
Spazilton
Ok,
Semi odd problem here. I have been doing some stability testing of my new rig, and while doing this I have had orthos fail on 2 seperate occasions at the EXACT same spot(+/- 2 Seconds) in time at 30+ minutes. That is what I have logs to prove. I have seen it fail 3 other times at the same point with all the same error within +/- 2 seconds. 33 Min into the test. It is on different iterations that it fails but I have never heard of it failing so many times within such a narrow time frame.
Here is my log hopefully I can get some input. In all my years of using Prime, I have never seen a setup fail in the same place 3 times in a row unless it was instantly.
Any suggestions? Anyone ever experience this?
Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 1791 Time: 15
CPU: 3600MHz FSB: 399MHz [400MHz x 9.0 est.]
4/10/2007 10:38 PM
Launching 2 threads...
1:Using CPU #0
2:Using CPU #1
1:Beginning a continuous self-test to check your computer.
2:Beginning a continuous self-test to check your computer.
1:press Stop to end this test.
2:press Stop to end this test.
1:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
1:Torture Test ran 1 minutes 27 seconds - 0 errors, 0 warnings.
1:Execution halted.
2:Torture Test ran 1 minutes 27 seconds - 0 errors, 0 warnings.
2:Execution halted.
4/10/2007 10:48 PM
2:Using CPU #1
1:Using CPU #0
2:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
1:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
2:Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
1:Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
2:Test 4, 4000 Lucas-Lehmer iterations of M19174369 using 1024K FFT length.
1:Test 4, 4000 Lucas-Lehmer iterations of M19174369 using 1024K FFT length.
2:Test 5, 4000 Lucas-Lehmer iterations of M18874369 using 1024K FFT length.
1:Test 5, 4000 Lucas-Lehmer iterations of M18874369 using 1024K FFT length.
2:Test 6, 4000 Lucas-Lehmer iterations of M18874367 using 1024K FFT length.
1:Test 6, 4000 Lucas-Lehmer iterations of M18874367 using 1024K FFT length.
2:Test 7, 4000 Lucas-Lehmer iterations of M18474367 using 1024K FFT length.
1:Test 7, 4000 Lucas-Lehmer iterations of M18474367 using 1024K FFT length.
2:Test 8, 4000 Lucas-Lehmer iterations of M18274367 using 1024K FFT length.
2:Test 9, 4000 Lucas-Lehmer iterations of M18274369 using 1024K FFT length.
1:Test 8, 4000 Lucas-Lehmer iterations of M18274367 using 1024K FFT length.
1:Self-test 1024K passed!
1:Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
2:Self-test 1024K passed!
2:Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
2:Test 2, 800000 Lucas-Lehmer iterations of M163839 using 8K FFT length.
1:Test 2, 800000 Lucas-Lehmer iterations of M163839 using 8K FFT length.
2:Test 3, 800000 Lucas-Lehmer iterations of M159745 using 8K FFT length.
1:Test 3, 800000 Lucas-Lehmer iterations of M159745 using 8K FFT length.
2:Test 4, 800000 Lucas-Lehmer iterations of M157695 using 8K FFT length.
1:Test 4, 800000 Lucas-Lehmer iterations of M157695 using 8K FFT length.
2:Test 5, 800000 Lucas-Lehmer iterations of M155649 using 8K FFT length.
1:Test 5, 800000 Lucas-Lehmer iterations of M155649 using 8K FFT length.
2:Test 6, 800000 Lucas-Lehmer iterations of M153599 using 8K FFT length.
1:Test 6, 800000 Lucas-Lehmer iterations of M153599 using 8K FFT length.
2:Test 7, 800000 Lucas-Lehmer iterations of M147455 using 8K FFT length.
1:Test 7, 800000 Lucas-Lehmer iterations of M147455 using 8K FFT length.
2:Test 8, 800000 Lucas-Lehmer iterations of M143361 using 8K FFT length.
1:Test 8, 800000 Lucas-Lehmer iterations of M143361 using 8K FFT length.
2:Test 9, 800000 Lucas-Lehmer iterations of M141311 using 8K FFT length.
1:Test 9, 800000 Lucas-Lehmer iterations of M141311 using 8K FFT length.
2:Test 10, 800000 Lucas-Lehmer iterations of M135169 using 8K FFT length.
1:Test 10, 800000 Lucas-Lehmer iterations of M135169 using 8K FFT length.
2:Test 11, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
1:Test 11, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
2:Test 12, 800000 Lucas-Lehmer iterations of M163839 using 8K FFT length.
2:Self-test 8K passed!
2:Test 1, 560000 Lucas-Lehmer iterations of M212991 using 10K FFT length.
1:Self-test 8K passed!
1:Test 1, 560000 Lucas-Lehmer iterations of M212991 using 10K FFT length.
2:FATAL ERROR: Final result was CA7E6EBC, expected: 0555250D.
2:Hardware failure detected, consult stress.txt file.
2:Torture Test ran 33 minutes 29 seconds - 1 errors, 0 warnings.
2:Execution halted.
1:Torture Test ran 33 minutes 29 seconds - 0 errors, 0 warnings.
1:Execution halted.
CPU: 3501MHz FSB: 388MHz [389MHz x 9.0 est.]
4/10/2007 9:25 PM
1:Using CPU #0
2:Using CPU #1
1:Test 2, 560000 Lucas-Lehmer iterations of M210415 using 10K FFT length.
1:Test 3, 560000 Lucas-Lehmer iterations of M208897 using 10K FFT length.
2:FATAL ERROR: Final result was 3E67D273, expected: 0555250D.
2:Torture Test ran 33 minutes 27 seconds - 1 errors, 0 warnings.
2:Execution halted.
1:Torture Test ran 33 minutes 27 seconds - 0 errors, 0 warnings.
1:Execution halted.
Here is another one that is within 9 seconds..
4/9/2007 6:22 PM
1:Using CPU #0
2:Using CPU #1
2:Test 2, 560000 Lucas-Lehmer iterations of M210415 using 10K FFT length.
2:FATAL ERROR: Final result was 79E9B845, expected: 3FC3CCD7.
2:Torture Test ran 33 minutes 36 seconds - 1 errors, 0 warnings.
2:Execution halted.
1:Torture Test ran 33 minutes 36 seconds - 0 errors, 0 warnings.
1:Execution halted.
I understand that the CPU is most likely unstable, what I don't understand is how it can fail within such a close timeframe after 33 minutes.
Anyone?
I'm no expert, but I wonder if its a certain zone in your ram. As your ram fills up it eventually reachs a spot that has errors. Memtest could tell you that.
Could just be that there is an especially sensitive calculation occuring at that point - looks like core 2 is failing at about the same point - the beginning of the second test using 10K.
Well I went back on the same setup and ran OCCT, crashed in less than 90 seconds.. I guess for dialing in this 680i I am going to use OCCT.
you might as well run memtest and see if you can rule out your ram or not.
i agree, download memtest, put it on a cd, use that cd to boot, and just test out the ram first.
at least rule out that much before messing around with other settings.
Agreed. If it's a new rig, are you overclocking? Is your bios setup properly? If everything is running at stock and at the proper setting, you should run memtest.
Yea its already been through a mem-test cycle. I normally do around 2-3 days worth of burnins before I even start overclocking.
As a matter of course I normally set up new ram to run for 24 hours at rated voltage speed and timings.
It passed 24 Hours, 2.25v 4-4-4-5-12 @ 500Mhz with 0 errors.
However, I think the i680 does have some..um..Issues when it comes to memory dividers.
I found running Linked and Synched on the i680 is a hell of a lot more stable than running Async mode.
I swear this i680 setup has been nothing but one pain in the ass after another.
At stock speeds your processor is crashing? If thats the case it seems to be crashing at the same test. It could be because the heatsink is seated improperly and every time that test stresses a certain portion of the core without proper cooling, it immediately overheats and fails the testing.
And if you're not running it at stock speeds then you might just have an unstable overclock. :p
