tronmaster
- Feb 2, 2004
I purchased a multiple hard drive enclosure which holds 4 sata hard drives. I enabled my JMicron raid setting in the bios and also installed the JMicron software from Asus' website. I formated all hard drives and I have installed files onto them.
So with the JMicron software in Windows Vista, it seems I can set these hard drives to a JBOD raid setting. I follow the steps, and it asks me which is the primary hard drive, the program states no data will be lost. However, the next step ask for a another hard drive from the list.
This part I am worried about, will all data be lost on 3 of the 4 hard drives while it sets it to a JBOD configuration? The reason why I want to do this is because I have another computer without an esata connection, I was going to use an ESATA to USB 2.0 converter, however, the computer with Windows Vista 32-bit with no esata only recognizes 1 hard drive (the primary) and the other 3 don't show up at all.
Or do I just need to get a ESATA PCI-E controller card for the Esata-less computer?
Thanks for your help.
