ChristianVirtual
[H]ard DCOTM x3
- Feb 23, 2013
I would need to help of the most powerful folding team and the knowledge you guys cumulated:
until last week I was running on an Asus P8Z77 one GTX 780 in the slot close to the CPU and one GTX 660 Ti on the most distant slot; keeping the middle slot free some another GPU. The 780 has the monitor connected and is the primary screen. OS is Ubuntu 13.04; 319.xx driver with daily reboot.
Now I got a second GTX 780 and added it to the board; setup went smooth; Seasonic PSU is not breaking and folding on all three GPU cards is running; around 360kPPD with some help of CPU:4 and CPU:3 (sorry, a low number for here, I know
When looking on the PPD, temps and GPU-memory usage I realised that the primary 780 card get some hit in PPD and also run on higher temps compared to the second 780; difference can be up to 10kPPD (I want those !!).
In oder to harvest those additional points and reduce wasted heat (and potentially energy) I wonder what do to to achieve two alternatives setups
1) use the iGPU as primary screen (connected via HDMI); but still folding on all NV cards
2) use the outside 660 TI as primary card
For option 1) I tried in the past but couldn't get the NV driver running and FAH folding; I Needed at least to have one monitor connected to any NV card.
For option 2) How could I convince the BIOS to use the outside slot as primary GPU ? Didn't find any hint in the manual or Google.
Based on the huge form factor of the 780 I can't physically swap the graphic cards; some pins on the MB would be in the way.
Thanks in advance to get me more points
Christian
Christian
