Bloodgod42
- Nov 20, 2005
Ok, so I accidentally started a second instance of the GPU client, and to my suprise, it started folding. I let it run overnight just to see what would happen (thinking 1 or both would fail to send at some point) and in the morning it seems im pulling the same ppd (5000-ish) as a single instance. I checked my gpu temps and again, to my suprise, my max temp had actually dropped 15c.
Same points with less heat dissipation is FTW in my book! Is there any draw back to folding this way?
Thanks for any input.
