Hello all,
we're currently in the process of building a new villa and the guys from networking company came to install the cables today.
My original plan was to connect all cables (cat 6) to the server room which is located on the first floor (the villa is 3 floors), however the cabling guy told me that they all must go to the main DP which is on the ground floor (because the municipality says so), then after doing a patch panel there he will connect the other end to the server room (which is now 1 floor above). The problem is that there isn't a pipe wide enough for all (40~) cables to go through there.
He told me it is fine because he doesn't need all that space, he will just install around 3 fiber optic cables to the server room.
I didn't really get it, is this possible? I didn't really understand a lot because of his Indian accent but what I understood is that he can connect all those 40~ cables to little fiber-optics ones and then connect it to a switch in the server room and from there I can configure and control all cables.
Can someone clarify this for me please, how is it actually connected? I tried googling optic fiber cable to multiple ethernet cables but I didn't find anything clear.
