CrossFire already supports multimonitor displays with CrossFire enabled. SLI currently does not support it. Look for dual-display support with SLI this fall.
Hey Brent, when did this happen? When I enable CF on my 3007wfPHC, it disables my two 2007WFPs.
What cards? Latest Drivers?
Why doesn't/can't SLI support multi-displays anyway?
I always thought it was strange when SLI has been around for some years already and ATi can manage it with their CF.
It was added in Cat 8.3 I believe 2 monitors max.
Update: Vista only
Another interesting feature of the Catalyst v8.3 drivers brings added flexibility to multi-monitor users under Windows Vista. In the past, users were required to disable CrossFire to watch certain types of video or to utilize additional monitors. But with the Catalyst v8.3 release, that is no longer the case. With cards from the X1800 series on up to todays HD 3000 series, utilizing an extended desktop in a multi-monitor configuration does not require CrossFire to be disabled.
He meant for regular desktop GPU's, and not Quadros which cost way more and are for other uses.
CF should support multi-monitors, strange it doesnt for you
Update: Vista only
They're not that expensive on the lower end and they game just as well as their geforce equivalents.
I suppose you wouldn't have a problem spending $1,500 on an 8800GTX then? http://www.newegg.com/Product/Product.aspx?Item=N82E16814133213
I realize you said lower end, but that is an even more pointless. Cheapest Quadro newegg caries is $60, and it tops out at DX7 support (I don't know how the models compare, but that has got to be pre geforce4). I can get an 8600GT for $60. Of course, since this is about SLI, once we limit the search to only cards that support SLI, the cheapest ends up being $800 for what looks like a 7-series card (cooler would suggest 79xxGT, but I'm not sure).
And from what I've seen of "workstation" cards, they rarely game as well as their equivalents as the drivers aren't optimized for games, and as such often take a performance hit.
ATI's is not limited to two screens. I've seen up to eight, using four cards. (http://www.youtube.com/watch?v=A3jpG3rv4zI) XP is limited to ten screens, I assume Vista is as well, and DirectX limitations prevent you from using more than four-way SLI or Crossfire anyway.
ATI CrossFireX Technology
Expand and conquer! ATI CrossFireX is the ultimate scalable Multi-GPU solution that allows up to four graphics units installed in a system using AMDs motherboard.
More horsepower for game playing
Allows gamers to scale performance according to their budget
Multi-display support (up to eight monitors)
Easy plug-and-play upgradeability for even better 3D performance
I'm not going by the FAQ, I'm going by confirmed reports. I found that video through a HardOCP article, so it's not just me.
Also:
http://game.amd.com/us-en/unlock_radeon3800series.aspx
