Xilikon said:There is also media players from D-Link :
Malk-a-mite said:The biggest problem I've read about with devices similar to these is the limited selection of
files they can/will play. Definately dig around the net for user reviews before picking one up.
Also the 520 does WPA-PSK were the 320 only does WEP.
Xilikon said:you should reencode files to a compatible format anyway.
Malk-a-mite said:I went with the orginal Xbox soft mod'ed to use Xbox Media Center with my file server holding all the content.
You can pick up a used xbox for around 100 bucks. If you don't want to deal with the mod'ing check places like Craigslist for pre-mod'ed boxes in the range of 80 to 200 depending on the level of mods (straight soft mod for XBMC, or more involved setups like 160gig hard drives added).
EDIT:
Might as well link to the howto while I'm at it.
http://www.productwiki.com/microsof..._xbox_to_xbox_media_center_in_30_minutes.html
