Multicast IGMP/PIM
utshost
New to this MC video stuff.
trying to setup a MC stream to go to two different locations. At the head end I have a device the generates the MC video from there it goes into a cisco 3750 port 24. Port 1 goes to one remote site same subnet and is working at the site. It then gets put out over the air and picked up at that site and turned around on a different MC. To be picked up at the headend. this is not working unless I turn off igmp snooping. Port 13 is going to the second site and I can not get the MC to show up. Its all switchs and no router.
basic drawing. port 1 and 13 get sent to a nid that is only a fiber transport to the sites.
MC Video source ----- Cisco 3750 ------- SG 300 site 1 ---- IP rec mux --- transmitter
227.1.1.50 |---------------- SG 300 site 2 ---- IP rec mux --- transmitter
site 1 sends back MC 227.1.1.150 to a device on port 5 on the 3750
site 2 sends back MC 227.1.1.100 to a device on port 17 on the 3750
I think I botched the 3750 config pretty good....
headend and site one are 10.10.4.x network site two is 10.10.6.x
Building configuration...
Current configuration : 3182 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname xxxxx
enable secret 5 $xxxxxxx
no aaa new-model
clock timezone UTC -6
clock summer-time UTC recurring
switch 2 provision ws-c3750g-24ts
system mtu routing 1500
ip subnet-zero
ip routing
ip multicast-routing distributed
ip igmp snooping querier address 10.10.4.5
ip igmp snooping querier query-interval 25
ip igmp snooping vlan 1 querier version 2
ip igmp snooping vlan 1 querier address 10.10.4.5
ip igmp snooping vlan 1 querier query-interval 3
ip igmp snooping vlan 1 static 227.1.1.150 interface Gi2/0/5
ip igmp snooping vlan 1 static 227.1.1.50 interface Gi2/0/13
no file verify auto
spanning-tree mode pvst
spanning-tree portfast bpduguard default
spanning-tree extend system-id
spanning-tree vlan 1 priority 0
vlan internal allocation policy ascending
interface Loopback255
no ip address
ip pim sparse-mode
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
switchport block multicast
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
no switchport
ip address 10.10.6.5 255.255.255.0
ip pim sparse-dense-mode
spanning-tree vlan 1 cost 19
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface Vlan1
ip address 10.10.4.5 255.255.255.0
ip pim passive
ip default-gateway 10.10.4.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.4.1
ip http server
ip http secure-server
ip pim autorp listener
ip pim ssm default
control-plane
line con 0
passwordxxxxxxxxxxxxx
login
line vty 0 4
password xxxxxxxxxx
login
length 0
line vty 5 15
password xxxxx
login
length 0
end
thanks for any help.
Even among semi-experts, multicast is still a black art. I suspect that's why you aren't getting many responses. It's hard to determine multicast issues and functionality from a config. Even the TAC would need to use debugs and show commands during the multicast attempts.
On your routed G2/0/13 interface, have you tried removing the ip pim sparse-dense-mode command put in ip igmp snooping querier instead? Will it take it?
