so I want to plan out the ability to make my entire house be able to access a media/file server. I want to have a single backend storage system that all of the front-ends can access over the network. There's just a few things i'm not clear on. Here is a diagram of how I envision the setup and my questions are after.
what do i need in order to plug in the coax from the cable company? I'm talking about the high level at this point. would it be best to use the backend server? If so, how do I change channels and the like? do I use a separate dedicated PVR system? or do i just use one of the front-ends?
for the front-end systems, I want something small that doesn't cost much. I only need one system that can handle 1080p, which the ps3 should be able to do, correct?
once i figure out where the pvr portion needs to go, then i can figure out what kind of specs i'll need.
sorry if my questions sound stupid, but something's just not clicking with me.
thanks.
thanks.
