The multi is not stressfull by itself. You can set the multi as high as you want without worrying about hurting the CPU. However, keep your eye on the final clockspeed; too much heat or too high of a voltage can/will damage your CPU. There are a number of overclocking guides here, I would search for and read a few of them before you do much of anything.p-n-p said:Is a higher multiplier "stressfull" on a cpu like on intell extreme series. how high can you go thats considered not stressful ? Is x14, x15 too much ? Is there lag when using a high multi?
