I've seen this being requested a few times, i finally figured out how to do it without any 3rd party program.. Its easy, can't believe i didn't try it earlier (i tried all sorts of stupid programs).
This is just for reference
You need an image editor, i use PS CS3 anything will probably do. if you need a free editor try Gimp.. (Paint would probably even work)
my Setup consists of
Main 1920x1080
Secondary 1050x1680 on the Right.. (Verticle 2001FPW)
1. calculate your dimensions of the total wallpaper (must be exact)
in my case its 1920 + 1050 Wide = 2970
and the larger of the 2 heights (1050 or 1680)..
my dimensions are 2970x1680
create your new blank image with those dimensions.
2. Take the image you want on Screen A , in my case its on the left and size it to be exactly to Screen A's Resolution. In my case its 1920x1080. Now put this into your large Image and set it at the correctly location relative to your setup.
In my case i put a 1920x1080 picture in top left of the larger 2970x1080 image.
3. Take the image you want on Screen B, and size and position it the same. In this case i size it to 1050x1680 and position it on the Right size of the 2970x1080 image.
Example (120k)
4. Save Image and goto personalize display. Select thew new image and choose Tile, the key is Tile stretches over both screens, either other setting duplicates the wallpaper..
Results 117k)
and enjoy![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Main 1920x1080
Example (120k)
Results 117k)
and enjoy
