Multi-monitor troubles
MM983
My current machine is a 1.5 ghz AMD 1800+, with 768MB DDR Ram. The main video card is a GeForce4 Ti4400 and there is also a Number 9 128 series 8MB card (cheapy one :p).
I currently have two monitors hooked to the geforce4 card with no problems at all. I put the number9 card in and Windows saw it and installed just fine. However, when I try to activate the monitor on that card, I get a blue screen after I hit apply. It begins a physical memory dump, with a reference to a file called "ctac32k.sys".
Why would I be getting this screen? Can my computer not handle three monitors at the same time?
Thanks for any information provided!
first of all, this is in the wrong section. anyways, have you tried another card? it might be bad.
I don't understand how this is in the wrong section condering it is hardware related. Secondly, the card is good.
He means that you should've posted this in the video card or display section.
