As I'm learning more about subnetting I've found myself confused by a specific scenario. Here is what it reads from the Configuring Windows Server 2008 Network Infranstructure self-paced Training Kit:
Voter Hall
208.147.66.0/26
Twilight Hall
208.147.66.64/26
Monroe Hall
208/147.66.128/26
Sunderland Hall
208.147.66.192/26
All of which share a common router.
I for one cannot understand why this makes any difference, and splitting it up would benefit a network how? If it is all on a 255.255.255.192 subnet, it is essentially doing the same thing, right? I guess it does look cleaner/more organised. The only thing I can see useful in this architecture is in a network diagram. Am I missing something?
Bah, after writing this I think it is sinking in...dammit, and that was a lot to copy out of the book.
Suppose you are designing a campus network with 200 hosts spread over four buildings - Voter Hall, Twilight Hall, Monroe Hall and Sunderland Hall. You want each of these four buildings include 50 hosts. If your ISP has allocated to you the /24 network 208.147.66.0, you can use the addresses 208.147.66.1 - 208.147.66.254 for your 200 hosts. However, if these hosts are distributed among four physically separate locations, the distance among them might be too great to allow the hosts to communicate with one another by means of a local network broadcast. By extending the subnet mask to /26 and borrowing two bits from the host ID portion of your address space, you can divide the network into four logical subnets. You can then use a router in a central location to connect the four physical networks.
Voter Hall
208.147.66.0/26
Twilight Hall
208.147.66.64/26
Monroe Hall
208/147.66.128/26
Sunderland Hall
208.147.66.192/26
