Multi-GPU setup help
Avalanche
Pendleton - Learn It, Live It, Know It
I have the GPU client setup on my rig (I think, lol) and have gotten it running on one of two 8800 GTs I have installed. However, when I go to add the -gpu 1 flag for the second card, F@H gives me an error saying:
At present your GPU is not supported or you need a current driver.
You may wish to consider running our standard client, which you can download at folding.stanford.edu
I have SLI disabled and driver version 195.62
sirmonkey1985
[H]ard|DCer of the Month - July 2010
ahh you need the 258.xx or newer drivers otherwise you need a dummy plug for the second card.. the 258.xx or newer dont require it..
zero2dash
I never needed dummy plugs with 195.62 in Vista or 7.
Do you have the forcegpu_nvidia g80 flag in both of your clients?
What client are you using...gpu2 or the beta gpu3 client? Need more info. ;)
SazanEyes
[H]ard|DCer of the Month - January 2011
If you enable SLI with the current drivers, it should work.
If you update the drivers, make sure SLI is disabled, and if necessary add the "-forcegpu nvidia_g80" flag to the command line.
