Multi Fan Controller
BigRon
I currently have a Tsunami case that has 2x120mm and 1x92mm fans in. I also have a rather hefty 120x38mm fan sat on my XP-120 :D Im about to upgrade to SLI'd BFG 7800GTX OC 256's. I'm thinkin this things not gona get any quieter...
All of the fan controllers I like the look of have the 3pin mobo style header for the feeds. I know I can get adapters to go to molex but are these ok to drive 3x120's and a 92?
Also would it still reg the fan speed?
I like the style of the thermaltake hardcano 13/14, any other recommendations? (must be single bay and black)
Thx
They will run those fans just fine.. I use a vantec fancontroller four rheostat control circuits, controlling 5 fans. 3 X120mm fans and 2 x 80mm fans over my hdds. No problems. Use the three pin connections.
WZ
you could also try the sunbeam rheobus, its pretty powerful. 3 pin headers. comes in silver and black. controls from 0-12v
Thx peeps,
Think I'll get the hardcano 13 with the card reader in it.
Price wise Ive kinda not got a budget atm :D
any other recommedations?
