I tried in the Video Card section to no avail, perhaps someone here has tried it?
Multi Display Question HydraVision
Yup still looking for the best set up.
Anyhow seems I will have get a couple satellite cards. I need to drive 6 monitors, I am wondering how well does Hydravision work with this set up. And what can you guys recommend being the cheapest and least power hungry solution, see sig, I only have 600 Watts PSU to work with, and its Epsilon, also its powering my H2O as it is. Will hydravision let me expand and move around the desktop side to side, up and down etc. I am basically giving up on PC gaming, as theres no way to play cheaply on this set up, at least not for now, nor any incentive, maybe when the next gen cards arrive.
[ 1 ] [ 2 ] [ 3 ]
[ 4 ] [ 5 ] [ 6 ]
Anyhow can I go from 1 to 4 by bringing my mouse down, etc? And then if I got to the side it goes to 5 then from 5 I go up to will go to 2. Hydravision works great on my dual Monitor set up, wondering if anyone also did this with many monitors, I believe it could keep going to the side, but I rather go up and down if possible.
Anyhow any recommendations on which cards? I use 3DS sometimes, but not much, though I prefer if the card can do opengl, or handle the viewpoint. I have 1 PCI slot free and 1 PCIE slot free. I would like the cheapest possible solution, with all DVI going into the monitors.
[ 1 ] [ 2 ] [ 3 ]
[ 4 ] [ 5 ] [ 6 ]
