Zardoz
- Aug 27, 2000
I got my LCDs Friday, and got them setup today... all I can say is WOW!
BigBadBiologist said:Nice. I love mine (but only have one with a 19" FD as the other). Are they connected to the 6800? If so, do you have your desktop set up as two distinct desktops or do you have it spanned?
BigBadBiologist said:so your desktop pic (background) is really 2 different pics?
griever2004 said:are you running one on vga and the other on dvi...
if so, do you notice any differences?
color?
is therre a distinct color differentiation (out of the box)?
text?
sharpness?
etc.
I plan on getting a pair of those as well, but im limited on getting a decent NVIDIA video card with Dual DVI for smooth play on the latest games like HL:2 and Doom3 and for graphic work.
XFX 6800nu/GT/U
6800GT/U Gainward Golden sample
and I think all the 6800U's have dual dvi, if not most. But I dont have enough money to buy an ultra
Anyway, your opinion on the differences might help me decide whether I should stick to getting a dual dvi card, or 'hopefully' save myself some money by purchasing a VGA/DVI card like a BFG 6800 OC.
Thanks so much in advance.
Zardoz said:I do have one running on DVI (digital) and the other is on the d-sub (analog) there is a differents. The digital one looks sharper and you can say more aureate looking. I have tried to mach the analog one as much as I can using the forceware color correction and monitor controls. It's not bad, but if your looking for it you can see it. I think dual DVI would be the way to go. but if you was not able to do that, I would not let itbother you...
firey-eyez said:you could get a dvi splitter box; fairly expensive but i think it would do the trick
jonavin said:Hmm..Splitter box? wouldn't that just give you the same image on both monitors? I was thinking about getting DVI/KVM switch, but they are expensive, about $250 for 4 port.
Zardoz said:do the trick for what?
firey-eyez said:pretty much what it sounds like itd do..splits the dvi into 2 or more outputs depending on what kind you get.
it would be to get both screens hooked up with dviZardoz said:ok, but why would I want the same image on 2 monitors?
