zero_vertical
- Jun 6, 2006
I'm looking to use my 3.5" bay on my htpc for one of these multi card readers. There are a fricking billion of them on the market, and most of them are from brands i'm not familiar with.
I'm leaning towards the ones with the floppy as well as the multi reader capabilities, and i want an internal usb connection (as opposed to some of them that you have to run a USB out the back of your case to an external female plug - rediculous)
anyways, does anyone have any positive experiences to report on these? I've listed the one's i'm considering right now below. It's just that the newegg reviews are kind of on the fence for most of these.
http://www.newegg.com/Product/Product.asp?Item=N82E16821104104
http://www.newegg.com/Product/Product.asp?Item=N82E16813998514
if there are any positive experiences or suggestions, they'd be much appreciated.
thanks in advance
zv
thanks in advance
zv
