I have a table with two integers representing rooms and buildings. I want to create a trigger for on insert and update to make check if there are 100 rooms in the building. If 100 already exist, I want to rollback the update. I think I can figure the condition out but I'm not sure about the syntax.
What do I write if I want to check if the building number of this new tuple is equal to 3. if it is equal, rollback, else allow the insert.
CREATE TRIGGER dbo.AddRoom
ON dbo.RoomAndBuilding
AFTER INSERT, UPDATE
AS
BEGIN
Condition and Actions
END
GO
Can someone help me out or guide me to a good resource. Thanks.
AS
BEGIN
END
GO
