Hi I'm having two problems with my computer.
1. When starting MSN Live Messenger 8.5 (newest version) I get an error which states "msnmsgr.exe - unable to locate component. This application has failed to start because MSOERT2.dll was not found. Re-installing the application may fix this problem". I have tried reinstalling but it does not work. I have also tried downloading the dll file and placing it in the system32 folder but that only gives me a different kind of error. This error gets very annoying because it's always appearing when messenger is open. It seems to occur every time someone changes their status.
2. I Have Windows Vista and which is working fine except that the OS tends to get to a very weird behavior when resuming from hibernation. It's totally unable to connect to the internet, I can't even access the network settings and when i try to shut down the computer "logging off" just appears endlessly and nothing happens, the computer isn't working at all and I have to force it to shut down by holding the shut down button. That's the only way to get the internet working again. I used to use sleep a lot but stopped because the same problem was haunting me but even more often. Hibernation makes it happen less often but it happens a lot though.
