MSI Z68a with 3570k Overclock
Get_out_and_Push
Hey guys, so I just upgraded to an unlocked CPU. My mobo needs new bios to run with Ivy Bridges so I did that and no problems.
Computers running fine, but I can't overclock the CPU for some reason. I can change the multiplier in the bios, but it never actually takes effect. For instance I can change it to say 38, the bios say the processor is running at 3.8ghz, but when I boot into windows CPUz says the multi is still 34.
Any suggestions on what's going on here?
Thanks in advance
Sorry, I thought i put the whole motherboard model in the title. Guess not.
MSI Z68A-g43 G3 with an i5 3570k. That should be all that's required right? Various assortment of ram, not overclocking that at all and a hd7850
Ah yes, you did, my bad. When I did mine, (I know different board), I had to actually hit the enter key when I put in the multiplier. When I saved it and booted into windows, task manager and such still shows it as default. However using realtemp and cpuz like you did showed the correct (at the time) frequency. So generally it shows 1.6 until I apply a load, then it shows the 4.5.
The multiplier seems to stick in the bios, just not in the actual frequency of the CPU. My cpu doesn't throttle up or down, I turned that function off so in windows with CPUz it shows 3.4ghz, but the bios will show that processor as having a multi of 38 (default 34) and that the processor is running at 3.8ghz.
I don't see anything obviously incorrect, so I'm not sure what the problem is. I would try an optimized default load then only change this one setting. Maybe there is something else that you changed possibly that is inhibiting the OC.
I think the motherboard might be incompatible with changing the multiplier for Ivy CPUs...might be time for a mobo upgrade
I have an MSi Z68a-gd65-g3 with an i5 2500k. I haven't overclocked yet but I did a lot of research when I bought the hardware. The only reason my mobo got a silver instead of a gold from [H]ard|OCP is because of the bundled software. As a matter of fact, I think they had this exact same issue... Settings changes that didn't stick. I don't recall if the issue was only the windows utility or the actual bios pre-boot (or both) but I'm inclined to say it was the windows utility which appears to be what you're using.
Have you tried rebooting and changing these settings the old fashioned way in the BIOS?
I'm not using the windows utility (is there one? because maybe I will try that next), I'm using the bios to change the settings. Those are the UEFI bios, it's got the functionality to screen shot. But yeah the settings are sticking according to the bios, but the processor isn't changing speed. If you look in the top right hand corner it says the processor is being clocked at 3800 mhz, but then when you boot into windows it says the multiplier is still 34 and is at stock clock (3400mhz).
Ok, yeah in that case, check out the Windows utility. It's called ClickBIOSII (at least for my mobo it is). You should be able to find it under utilities on the MSi website for your board specifically.
They look really similar. Here's a screenshot of mine:
Also, I didn't have time to skim the whole article again, but I know [H]|OCP wrote something up on the bios settings not sticking and a possible work around. If memory serves me right, they had to play around between the windows utility and the actual bios to get it to work, but you'll have to see if you can find it as I don't remember for sure. Here's their write up on the BIOS for my board:
http://www.hardocp.com/article/2011/09/22/msi_z68agd65_g3_lga_1155_motherboard_review/3
Thanks in advance
I just had a similar problem with a 3770k.
This is what I found out. z68 and p67 will only overclock IVB to a multiplier of x39. Might not even do x39....my gigabyte p67a would only work at x37
You have two solutions.
Return chip get a 2700k or buy a z77 or x79 board
I got a MSI z77a gd55, onsale at newegg this week.
Well, I perused my BIOS last night and decided to test it out myself. I'm having the same issues.
CPU mult = 3.4 (CPU-Z shows 3.3 GHz still)
CPU target temp = 60C (fan stays the same speed)
CPU min fan speed = 87.5% (fan stays the same speed)
Although, when I go into the BIOS either in boot-up or within the Click BIOS windows utility, the settings all appear to be changing and sticking... they just don't do anything.
Looking for any help here as well.
