msi Z68A-GD55 (B3)
neel14
need to build a budget pc for my friend and m stuck on the mobo.my friend needs a z68 to use the igpu.hws d msi Z68A-GD55 (B3)?if any one f u hv experiences wid it.he needs to oc.has a 2500k
Why does he need the Z68 again? There is a great MSI P67 board that won the HardOCP gold aware in that price range.
Also what other things does he need in the MB, RAID? SATA 6G? 2 PCIe2x16 lanes? How many nics? Form Factor? etc.
Just off of newegg given the price range these are the ones (by brand) I would recommend in order:
1) http://www.newegg.com/Product/Product.aspx?Item=N82E16813131759
2) http://www.newegg.com/Product/Product.aspx?Item=N82E16813130606
3) http://www.newegg.com/Product/Product.aspx?Item=N82E16813128512
You missed the part where the Intel HD IGP was required. The P67 can't utilize that.
I didn't "miss" it, there was a bunch of stuff all garbled up, I wanted to make sure what he was saying before I just assumed. Also it doesn't explain 'why' he needs that. Some people think they need something and really they don't. So just asking for clarification. Note, I also gave several suggestions anyway.
I have a system built around that mobo/cpu. I'm very happy with it.
2500k
Z68A-GD55
8GB Vengeance 1600MHz
H80 Cooler
Carbide 400R case
M4 SSD
(4) WD 2TB Drives
Asus DVD+-RW
Radeon HD6850
Hauppauge HVR1800
All fans in the case are Cougar CF-V12HP 120mm PWM fans connected to a Akasa FC.6 controller. (minus the 2 on the H80, which are controlled by the H80)
