I ordered this board last week and installed all the components and it would not POST. So I RMA'd the board. I received the new board yesterday and same thing. The board was coming on for about 20sec. then shutting down. I then took out the cmos battery for 10 min. and now the system comes on and will not POST. It will stay on as long as I leave it on but no POST. I thought maybe it was my PSU mushkin enhanced 550 watt but I put it back into my OC'ed q6600 system and it worked perfectly, I also used my daughters antec 550 wat psu and same problem. I have that system OC'ed to 3.6 ghz. My components are as follows:
MSI x58 Platinum
i7 920 cpu
2 gig ocz reaper ram (1333 version)
Mushkin 550 enhanced PSU
8800gts GPU
DD i7 waterblock
dtek db-1 pump
Any help will be greatly appreciated. By the way I am more of an enthusiast than a gamer.
PS. I am using an MM H2G0 case so I do not have a speaker will that matter for beep codes?
MSI x58 Platinum
i7 920 cpu
8800gts GPU
DD i7 waterblock
dtek db-1 pump
