MSI RS480M2 no POST
posten
need some quick help, in short, I think my board just tanked.
it's an MSI RS480M2-IL....based on the radeon xpress 200 chipset. its worked well for about a year and a half or so.
i ugraded the CPU to an X2 3800+ and used that opportunity to start fresh with a raid 1 array on some WD's...sadly coupled to the onboard god-forsaken Silicon Image 311x sata chipset. avoid it at all costs. worked well for maybe 3,4 months, then recently, started getting some errors - raid 1 array in rebuild...it's had to rebuild at least twice in past 2 weeks. kinda getting old.
other day just get a BSOD (w2000)...some driver failed or something...didn't get the name...go to reboot. in short, it won't post. It won't even give the signal to power up my monitor.
began troubleshooting, though there's not much to do. no pci or pci-e cards in...disconnected optical drives, sata drives, cleared CMOS. I can't get this thing to come up for the life of me. no beep codes to aid.
I hear the opticals and sata HDDs spin up, seem ok. only hear the HDDs being read ever so briefly. the only clue the system gives me is that the CPU fan (AMD oem) powers up to its usual boot/idle speed, then attempts to spin up a little more (as it usually does and stays at that higher RPM as needed until windows comes up) but fails and returns back to initial RPM. it'll wait about two seconds and then try to speed up again (and fails again). this repeats endlessly.
I'm totally at a loss. I tried the drives, booting up with and without all optical/hdd drives plugged in and not...even used a PSU tester - enermax 430w is fine...swapped RAM around. was pretty sure resetting the BIOS would do it but obviously I was mistaken.
Let me know if you guys have any ideas. thanks for your time.
posten
