PRICE DROP ON GPU
Parting out my watercooling system, parts have seen usage of around 2 months in the following build.
http://www.overclock.net/t/1548834/...-fully-water-cooled-cooled-by-2x120mm-2x180mm
It's time to move on to a busy job and I have not gotten much use out of the machine.
Have retail box for MSI 295x2 and some WC parts
Only Distilled Water and dazmode protecter was used
MSI Radeon R9 295x2 $650 with waterblock and backplate
Aquacomputer Kryographics Vesuvius Radeon R9 295X2 Full Coverage Liquid Cooling Block - Nickel / Acrylic + active cooling backplate $180
Together for $700 -> $650
WC Parts (rads come with stop fittings)
D5 Vario pump with sleeved blue and grey cable $70
EK-CoolStream RAD XTX 120mm extra thick $40
Darkside 120mm thin rad $30
2 x White LED Enermax Cluster PWM 120mm fans $10 ea
3 x Cougar Hydro Dynamic Bearing PWM 120mm fans $7 ea
Misc 120mm case fans $3 ea
Alphacool NexXxoS XT45 Full Copper Dual 180mm $60 ($100 bundled with 2xAP182 fans)
2 x Silverstone AP182 180mm PWM fans $30 ea
All WC Parts = $220
WC fittings/adapters are shiny silver/chrome in good condition, some scratches on comp fittings
4 x EKWB 90 deg rotary adapters $7ea $28
7 x Enzotech 90 deg rotary adapters $7ea $49
10 x Swiftech 3/8" - 5/8" compression fittings $4ea $40
2 x Swiftech SLI connector 20 to 33MM (can be used as Male-Male adjustable rotary adapter) $7ea $14
1 x XSPC 4 way block with Water temperature sensor/display $15
1 x Koolance 90 Degrees Low Profile Swiveling Elbow Adapter $10
9m of Primochill Advanced LRT CLEAR tubing 3/8 - 5/8 $15
Bitspower Extenders (7 or 8 in total) and other misc adapters $60
30mm 50mm 40mm 15mm 20mm
18mm Dual Connecting Spacer Adapter Female/Female - Chrome
2x 12mm Spacer Dual/Connecting Fitting - Male/Male - G1/4
All fittings/adapters/tubing = $220
All WC parts + fittings/adapters/tube = $400
All of the above = $1000
Asus Maximus Impact VI Itx full cover motherboard block = $80
Feel free to make bundle offers via PM.
Contact to discuss shipping accepting Paypal
All WC Parts = $220
