I recently bought an MSI R9 290 which I've encountered a peculiar issue with my computer. It doesn't get detected after it either falls asleep or when it's shut down after being extensively used. When it first happened it was after my computer fell asleep when I forgot to turn my computer off before taking a rest. When I woke up and tried pressing the power button to wake the computer I couldn't get a signal even after swapping it's HDMI cable to a different monitor.
Anyways, I found this forum post by someone who had the same exact issue so I did what he did and opened up my computer, disconnected the GPU from the pci express slot and connected it again. It worked, so I simply disabled sleep mode which didn't bother me much anyways because bizarre behavior from my PC after coming out of sleep mode is pretty common.
It later happened again after I played a game for about an hour except I shut down the computer instead. The next time I powered it on my monitor wouldn't get a signal but it does detect the card because when I disconnect it the monitor displays "No connection" or something like that. I've confirmed it with two separate monitors.
Switching off the power and unplugging the cord does nothing. I have to physically remove the card from the PCI-E slot and re-connect it to get it to work again. Any ideas about what's causing this?
I've got a 700W OCZ GameXStream PSU with all the proper external power connectors plugged in so i don't think it's for lack of power. My motherboard, however, is kind of old with only a PCI-E 1.1 slot. Do you think that could be the cause?
Any help would be greatly appreciated.
