the motherboard specs say ddr2 800+. does this mean it will run ddr2 1200 at clock + o.c.?
btw someone told me that if i even goto to 2.1v on any nvidia motherboard i'm asking for a memory controller meltdown, any truth to this?
If not sure if the 750i boards natively support DDR2 ram faster than 800mhz, although with a nForce board you can run your RAM out of sync with a specific FSB divider, so you shouldn't have too many issues. Check to see if the particular RAM you have is compatible with that motherboard.
In general, nForce north-bridges for recent Intel processors (680i, 780i, 790i) are not known to be shining examples of quality or stability. Many people have had issues with controller meltdown when running RAM above 2.1v, but this was most prevelent with early 680i and 780i boards. The 750i has had a better reputation, so you may be in better shape. Still, before pairing any RAM with an nForce board, it pays to do research and due-diligence. Make sure the specific RAM you want to use has a good track record with the chipset.
