Yesterday, I received a P6N motherboard and an Intel e4400 and put it together with Artic Silver thermal grease. I had a bit of trouble putting the heatsink/fan on so I had to apply it a couple of times. I removed the paste each time with isopropyl alcohol and cotton swabs and reapplied only a little bit. When I started my computer up, it powered down and I started powering it up. This happened four times before I realized my CPU fan wasn't plugged in. Now, everything seems to be working fine but after checking SpeedFan and my task manager, the computer only detects a single core and it's temperature is 42C-48C at idle when my old one was usually 29C-33C idle (overclocked too!).
My question is if I somehow damaged my CPU be reapplying the thermal grease too much or if I permanantly damaged by overheating the CPU from starting it with the fan off.
Thanks.
Thanks.
