So I'm having some issues waking my PC from my XBox 360 (MCE Extender, it *does* send a magic packet).
That said, I got WOL to work once when I went into the BIOS and set the PC to use "BIOS" settings for Wakeup capabilities. However, the USB, and everything else is unresponsive so I had to do a hard reboot to get it up.
If I swap the Wakeup Capabilities to use "OS Setings", I can wake the PC only using the power button (not USB mouse or anything else, though it's plugged in through a USB hub, not sure if that matters). I can't wake up the PC using a WOL packet either.
So either I keep my PC on 24/7, which I don't like the idea of, or I can figure out this WOL issue. I'm open to ideas folks, so please if you have any.... lend a hand!
Thanks!
Thanks!
