MSI P67A-GD55... Front USB?
Just did some reading on that board, and it appears it has 2 JUSB ports, 1 is for USB 2.0, and the other is for USB 3.0.
It looks like you might be out of luck
Hey guys, I bought this:
http://www.amazon.com/Adapter-desig...l-connector/dp/B000V6WD8A/ref=pd_bxgy_e_img_c
But it's a single row 5-pin adapter that looks like:
And I'm trying to plug it into the front USB lead that's a 9-pin that looks like:
They don't seem to want to fit together. Any advice?
How are you trying to connect those all together?
Are you trying to go from a USB port to the Front USB with that?
You have to plug the 5 pin male side into the 5 pin female side.
Front panel USB to a rear USB port on the motherboard.
I'm trying to get the front USB to work by plugging its case header to a rear port.
OK, thats what I thought.
So have you tried my suggestion of plugging the 5 pin male into this part.
I can't recall which way to plug it in. But if it doesn't work one way, unplug it, and plug it in the otherway.
You shouldn't need to shut down to do this either, seeing as how you are just adding it like a hub.
Let us know.
Well I got around to plugging it in, and in the system tray it said that Windows was installing drivers for a "Generic USB hub."
Although when I plug in a device, nothing happens.
Here's what shows up in device manager:
Well it turns out those devices in the device manager were USB3.0 hubs, so actually the computer doesn't recognize my front USB at all.
I tried plugging in those cables together both ways, but the pins won't go all the way in?
