MSI P67A-G45 Active Phase noise
Dude420
I just put together a computer for someone else, everything works fine. However, there is one problem.
I notice on the MSI board that there's a high pitched sound and it seems to be coming from the active phase switching part of the board. I know it's them because each time the leds flash, the noise comes off for a second, then comes back. Does that mean it could be faulty, or is it just the way it is? It's not too loud, but my ears noticed the sound from 2 feet away. Is there a way to control the active phase?
Has anyone had any experience with this on their MSI boards?
Update: Ok, I went in the BIOS settings and the option was set to Intel SVID, I switched it to APS and it went away. When having Intel SVID on, it seems to have been using all the cores. Switching to APS using only some cores while idle. Anyway, I still don't know why the noise was there when Intel SVID was on.
