May 20, 2011 #1 J jmoyer n00b Joined May 9, 2011 Messages 36 I am putting my computer together now and I am in the BIOS. I changed to AHCI and enabled the SATA ports being used and reboot. The SATA connections are all not being detected still. I need help.
May 20, 2011 #2 bigdogchris Fully [H] Joined Feb 19, 2008 Messages 19,105 Typically, you don't enable SATA ports. They should be on by default. Have you double checked to make sure you didn't accidentally disable them? Also, what OS are you trying to install on the system, or are you trying to find drives connected to this system from within an OS?
