MSI-P67-GD80 Tri-fire capable?
TwistedAegis
I know that the 3rd card would be running at x4, but I don't think that should be too much of a bottleneck. I recall reading however that this board would not support a 3rd card (3x6970) but can't seem to find corroborating evidence (full disclosure: didn't look too hard, either).
If anyone here can give me a definitive answer, I would appreciate it. I think a 3rd card should give me confidence to run BF3 maxed at 2560x1600.
It would work. You would just see something like a 5%-8% decrease in performance over a full speed slot.
No, you cannot. Seems silly, but it's a limitation of the chipset. An easy indicator of tri sli capability is if you see equidistant pci-e 16x slots. if you look at the gd80, you'll see the added distance between the second and third slots.
Ah man I was really confident this entire time that you could run another card in the x4 slot with the penalty of reduced performance. I stand corrected, thanks for that.
