MSI Not Posting
aeromark86
I moved today and I think something might have gotten messed up in the move.
I have a MSI ms-7260 motherboard. It currently turns on, all fans turning, everything has power, but nothing appears on the screen. I thought it might have been the video card, but putting the card in another computer, it worked fine. I also put a different card into this MB to be sure, and nothing.
There are no beeps or unusual sounds at all upon boot up. This seems like an unusual error since if I damaged it in transit, it should just be broken somewhere obvious, not doing something like this.
Any suggestions on how to fix this?
UPDATE:
I got it to post, but only when i have a one-gig stick in the first slot. None of the other 3 work, nor does using a 2 gig stick in its place. It also doesn't like two 1 gig sticks. Starting to think I need a new MB. :(
I had a similar issue with a friend's MSI P45 board.
Slot 3 and Slot 4 would not work. So I could not run dual channel nor more than 2 sticks of memory.
If you can still RMA the board do it. Although you will wait a good 3~4weeks on the RMA.
something may have caused the bios to reset,
check your voltage setting alot of ddr2 defaults to 1.8 volts go in bios set it manually to what your sticks are rated for. then shut down and reinstall your other sticks
