MSI Neo4 Platinum SLI HELP
BlackMack
I got my MSI Neo4 Platinum SLI motherboard and Love it. But I seem to have a problem that no one can seem to help me with. First the ring down....
2 gig Corsair PC4400 (4 * 512)
2 MSI NX6800GT Vcards
Sony DVD and a TDK dvd burner
2 Western Dig 120gig HD set in raid
510 Watt PC Power and Cooling PSU
ok to my problem. Run great but will not turn off. Windows unloads and saves screen goes black but fans and PSU never stop. Returned first Motherboard get new one and same thing. Downloaded new drivers for everything. Still nothing. I am said to say the Guys at MSI are stumped. Maybe Someone out there will have an idea that may work!
I could be wrong but I'd suggest your Power Supply might be to blame.
The PSU is getting a shutdown request from the motherboard, but not all of the regulators are obviously shutting down. Since the fans are still running, the +12 volt supply is definitely not shutting down. Try replacing the PSU with another one and see if it stop's the problem.
agreed. try a different psu.
Yeah - I think mine was doing that also at first... I loaded up bios 5 beta 6 and have never looked back. Works like a charm and I got 3.1v settings for my vdimm now. :)
Put my PSU in my second pc But it is ATX 1 so I had to use an adapter. PSU worked just fine. Restarted it 5 time and worked great every time.
Also I have BIOS 3.6 on main PC. still does not shut off without me holding in the Power button for 30 sec. Any more ideas
