I still think MSI has totally arbitrary methods for coming up with memory frequencies. For the longest time their "Maximum Memory Speed" made no sense to me; as I understood it, it was supposed to be a ratio, i.e., setting it to 200Mhz would mean a 1:1 ratio, and if you set your HTT at 225, your memory frequency would also be 225, for example. However, it never worked that way, and setting HTT to 250 would result in a memory frequency of 208mhz. I don't even know where the hell that number comes from, as it doesn't even seem to be any common ratio. So I updated the BIOS and the same thing kept going on; whatever, if I want memory frequency to be 230, then I'll just put the HTT at 280 or something.
My new problem is that when the motherboard says the memory is running at ~240mhz, CPU-Z says it's running at 213mhz. What...on earth?
