MSI Neo2 Platinum or something else?
Dra
A little earlier, I was set on getting the MSI Neo2 Platinum, until someone brought up the fact that it doesn't calculate multipliers correct which leads to instability within the system. This is a result from trying to overclock with the board, but apparently it affects the system when it is at at stock speeds also. Should i be worried?
If it will infact cause issues within the system, could someone recommend a different board?
My specs will be:
Motherboard: ?
CPU: AMD Athlon 64 3000+ Retail
RAM: Corsair XMS 512MB
Video: (for now) Radeon 9600
HDD: Maxtor 80GB 7200 RPM 8MB cache SATA
Optical Drive: Lite-On 52X32X52 CD-RW
Case: Antec Sonata w/ True 380 PSU
OS: Windows XP Home
Thanks.
Right now I'm choosing between the Asus A8V Deluxe and the Abit AV8.
Thoughts anyone?
i try to stay as far away from VIA chipset based boards as possable.
that being said, i've never heard of the multiplier problem. a friend of mine runs the Neo2 Platinum and gets some pretty damn good overclocks with it. of course, he's running a FX55 and a cascade cooling system. but i do know that he likes it better than his 2 NF3 based Gigabyte boards and his Asus AV8.
