MSI Neo2 Platinum Bios Flash
gizo
I just got the X2 and flashed my mobo with the beat 1.96 bios. The bios flash went through okay. But I guess when you flash this bios, you need to assign a mac address for the nforce NIC. I neglected to do that since I didn't know I had to. What do you guys do when this happens?
1) Call the manufacturer for a MAC address?
2) Assign an arbitrary MAC address of your own?
3) Buy a NIC or dig up an old NIC and use that MAC?
flash the old bios, look at what mac addess it gives you, write it down, and enter it into the new bios ;)
so does this mean i'm fubared if i didn't back up the old bios?
I agree with everyone - the real question is - how is your board running with the X2?? Does it work properly? (it seemed to be questionable with that board)
the original mac address of the onboard nic should be on the board. Typically it's on a sticker that's on the top of the parallel port back panel connector.. (if your board has one, which it does)
The board runs fine with the X2 once i flashed it with the 1.96 beta bios. It hasn't crashed on me or anything.
I"m going to pull out an old nic to reflash my mac address with. Ah.. the joys of reflashing bios.
Hey Kmeson, did you have your ethernet cable connected to the realtek nic port and not the nforce nic port? cause this only affected the nforce nic port.
I don't have the same board as you. I have A8N-SLI Prem. nVidia has always allowed you to configure you're own MAC, atleast that was the case with my last two nVidia boards. I suppose something could happen during flashing which might nuke your MAC.
My question is, why didn't it nuke everything else?
:eek:
