Commander_HK47
- Jan 13, 2007
I have come across a road stop so to speak while over clocking one of my systems.
The general problem is that i can not run 3d applications(games) for more than a minute or two without the machine haulting(screen freeze) and then going to a black screen shortly
there after when i set the system bus to a speed that would divide the DDR Frequency to 246 or above(245 or below yields stable 3d gaming).
The thing is Memtest+ 1.65, Prime 95, and both ATi tool/Tray Tool produce no errors for hours on end when uesed to test the system(honest i would just let them run and work/play on another PC or my Xbox). I can also run Prime95 and ATi Tool at the same time and receive no error messages or system haults.
Current Specs & Values that Test A-OK but no 3d gaming:
450watt KingWin PSU
12V 20A
3.3V 28A
5V 40A
Fluke DMM shows good output on these rails.
2XDVD Drives one Sony the other is a NEC 2510A Burner
1X Seagate 160GB IDE drive
MB: MSI Neo2 Platinum orig/not the FR version
(with latest SideEffect bios)
NICs on,
USB on,
APIC on,
Legacy ports off(Com, ECT)
Processor: AMD 3000+
Venice
F-F-0-F-2F-DH-E3
@2.520MHz(280X9) ~ 1.58/1.60V
HT-L@840(280x3)
Temps(I/L): (32/48C)
Memory:
2X1GB OCZ5001024ELGEGXT
Slots 1&2(128 bit DC)
@252MHz
CPU/10
3-4-3-8-1T, TRC=12, TRFC 18
1.75V
GFX Card:
AIW X800XT
Bus:67MHz
8X
Apt. Size:256MB
SB Adressing: on, FW: off
1.60V
PCI Latency:255
Temps: (36/80c)
SB Audigy 2 ZS(PCI slot 3)
PCI Latency:32
56k Modem(PCI slot 5)
450watt KingWin PSU
12V 20A
3.3V 28A
5V 40A
NICs on,
USB on,
APIC on,
Venice
F-F-0-F-2F-DH-E3
HT-L@840(280x3)
Memory:
@252MHz
CPU/10
1.75V
GFX Card:
AIW X800XT
Bus:67MHz
8X
Apt. Size:256MB
1.60V
PCI Latency:255
Temps: (36/80c)
PCI Latency:32
