MSI NEO2 freezes after POST
Q.man
Ive ran into some weird problems on my rig... first off the computer wouldnt boot until i replaced my bfg 6800 ultra with some old 32mb video card. Then after that the computer freezes right when it says DMI POOL UPDATING so i really dont know what to do. Also, when i turn the computer off becuase its frozen i cant turn it back on without unplugging and repluggingthe power cord and switching the power switch on and off a few times. I tried abunch of of different things such as using one stick of ram at once, switching the ram around, replacing the ram, and taking out my sound blaster card. The motherboard is came with flashed with the 1.9 bios. If you have any ideas please help me out. Thanks
3200+ venice
MSI NEO2 Plantinum
2x512 OCZ Gold pc4400
BFG 6800 Ultra
Sound Blaster Plantium Pro
600watt OCZ powersteam PSU
2x74gb raptors
120gb WD Hard drive
did you try moving your raptors to a different sata connectors? I had this issue when i flashed to 1.8 and moving the cables from 3&4 to sata 1&2 fixed it.
The 1.90 BIOS is massively, massively fucked. It's unfortunate that your mobo came pre-flashed with it, because 1.90 is what led to the death of my Neo2. All you can really do is attempt to boot the system with the absolute bare minimum of devices; take out any controller cards, any sound cards, and try to boot the system. If that actually works, the very first thing you should do is flash to the 1.80 BIOS, and that should fix your problems.
Unplugging my controller card is the only thing that would get my system to boot into Windows; if I didn't do that, then the screen would stay blank and I would have to soft reset continuously. However, I didn't seem to have any problems with my 6800GT, so I don't know why your 6800 Ultra is causing problems.
