hey all,
i just recently purchased this motherboard from another [H]'er, along with a 2.4b p4. anyways, i install everything, go to turn on the computer, and nothing. here is what i sent to the seller in a pm:
well i got it all installed in my case, attatch the jumpers and cables, plug everything in on the back and go to power up. well, nothing. i decided to just not mess with it any more as it was late and i needed to get to bed. today, i take the case apart again, make sure ALL THE JUMPERS are in the right spot, and go to power it on again. well, the first couple times you push the button, the led's come on, the fans start spinning, but no post then it shuts off. the third time you push it, power will come on, and the fans spin at their peak rpm no post just continuing like this until you turn it off in the back. now, at first i thought "well maybe my video card is bjorked", so i replace it with one i know is working for sure. nothing but the same. then i think, maybe my power supply isnt powerful enough for the power drain from two hdd's and a pentium 4. its a 350 watt cogeden.
Any ideas on whats up? burnt psu? burnt mobo? processer?
