MSI Neo 2 Platinum Raid controllers
b2bpro
There are 2 sata controllers on this board. I'm wondering what is the best way to connect 2 drives for raid 0. Which two connectors should I use in order to load balance between the 2 controllers?
Use controllers 3 & 4 as they are locked, ie... overclocking wont effect them. 1 & 2 are effected by overclocking, are not native, and will require a 3rd party driver to setup.
I run a MSI K8N neo2 plat.
