MSI neo 2 plat
Aminotaur
OK well i have a MSI neo 2 platnium nforce 3 and AMD 64 well i have kingston 512x 3200 and found some old 256 pc 2700 underclocked a little and worked i have 2 green slots the ones i use right now and 2 purple ones well this girl gave me 256x2 of 2700 and i just cant get the purple slots to boot up the memory is fine any suggestions?
let me try to make this clearer 2 green slots = equip with 512 3200 and 256 2700, i want to add two 256 to my purple slots but wont boot up so any of you with mobo mem slots filled how u get yours to work
BigDaddy85 said:
cuz ddr 400 don't mix with ddr 333 lol.
yes it will, itll just downclock to DDR333 speeds.
if you want to make this clearer, please use punctuation. damn.
edit: finially figured out what the hell youre trying to say. when you boot up with all teh sticks in its trying to run them all in dual channel mode, and there is no way in hell thats going to work with all the memory mixing youre doing.
Why wont it work its all at ddr 2700... Anyone got any suggestions?
it wont work because you are mixing and matching memory brand and sizes and putting them in dual channel. you just can't do that.
correct, but imo not worth it. A64 demands more bandwidth than ddr333 rite?
not really, no. any performance drop would be negligible.
