Thought I put up a contribution thread for my first post.
(Sorry if this has been discussed already)
Unboxing: http://www.techenclave.com/reviews-and-previews/unboxing-msi-n460gtx-hwak-talon-attack-176821.html
Memory Whitesheet: http://pdf1.alldatasheet.com/datasheet-pdf/view/333512/HYNIX/H5GQ1H24AFR-T2C.html
Voltage Reg Chip Whitesheet: http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBgQFjAA&url=http%3A%2F%2Fwww.overclock.net%2Fattachments%2Fgeneral-volt-mods%2F152863d1272436883-ocns-vmod-squads-volt-mod-essentials-up6213datasheet.pdf&rct=j&q=uP6213&ei=mZ_cTIHOOMGclgfN7ZjfBQ&usg=AFQjCNFQ3QWKqIcKpBgE0ESvFn33WksFhQ
Review: None thus far
Been reading for weeks for an upgrade to my BFG 8800GTX OC.
Found this card and fell in love with it. Only issue is that this card is based on a non-reference PCB (just like the original hawk edition card) thus there will be no full water-block options for this card. Contacted MSI regarding a liquid cooling solution for the card. They promptly told me that there is none that they would recommend and that removing the stock heat-sink will void the warranty!
If you intend to push the OC on this card further. I suggest that you find a way to adequately cool the mosfets as they get flaming hot when you over-volt the card.
Hope this is some helpful information.
Zen
Zen
