MSI motherbaods....
BigGreg85
Whats with MSI not offering the drivers for its motherboards on its website.....i reformatted a HDD on a comp for someone and installed XP and now the onboard NIC wont work w/o the drivers....its the MSI-6585 if anyone can find it or has info on the board
Depends on the board. I wouldn't recommend a MSI for any high end system. However, the low end / mid range boards are great from my testing.
Yea i didnt build the system....so I probably wouldnt have used MSI...swapping the mobo isnt an option....i will just buy a new NIC i guess.
There are a few ways to do this.
1. WIndows update on XP will pick up almost any NIC in existance.
2. LOOK at the board. You will see a chip that is a NIC chip- it will either be from Realtek, Intel, Broadcom, or 3com (could be others, but not likely), then, armed with the part number, you can dig up a generic driver for that NIC. The chip on the board is the same chip that is being sold for purposes of making a NIC card.
Might I ask what MSI's "Name" for the board is? Like... KM2M-L, 655-MAX, etc etc?
If you buy a nic to fix this problem, i'm going to heckle you in this thread.
