Arcygenical
- Jun 10, 2005
Well this is disconcerting.
I'm changing cases (Finally doing a Powermac G5 mod...), and I noticed a bit of discolouration on the rear side of my MSI Arctic Mortar mATX board...
Removing the VRM heatsink, I'm greeted with, well, this:
Now, I've already RMA'd this board for bad VRM's. I've only had this board in my possession for the better part of a year since the last RMA. I actually had the memory VRM set on fire before :/.
Keep in mind, this board has posted, and worked fine this entire time... In a case with very good airflow (rear fan pointed directly at the VRM area, triple radiator exhaust directly above VRM area).
Usual workloads are keeping my Ryzen near stock, boosting perhaps 200mhz over the default 1700x clock range, without changing voltages. The system mainly sits silent these days, gaming sessions are <2hrs, Single monitor, streams 2k kbps video from a door camera once or twice a day over the internet, music, media streaming, Oh, and a 3d print station... Which I use about once a day.
Now, the damn thing was posting and still rock solid, but after seeing that, I wonder if yet another RMA is in order. BS MSI... And an aftermarket VRM heatsink FFS.
