I finally got all my new machine bits in one heap and built the machine up. Much to my horror - she no worky
I wrote to MSI's support via their webpage but I've not even received an acknowledgement yet so I thought I'd see if any of you have heard similar problems. This is what I wrote them:
Processor is an Athlon 64 3800+
Memory 2 (or 4) sticks of Corsair TwinX1024-3200XL Pro
Rest is irrelevant since I've tried it with everything out or disconnected... The only things I've left to try tonight are checking the rear bracket LEDs and trying it with the MB out of the case (short circuit check).
Thanks in advance.
Wayne
When powered on, the system displays a graphic splash screen with "Core Cell - extreme chip you need". It will not respond to keyboard input (caps/numlock don't work either). Sometimes after 2 or 3 minutes, it will continue to a boot screen showing the bios version (ami 3.0, 6/7/2004), the processor correctly identified and the RAM also correctly identified. It lists no SATA or IDE devices and continues to ignore all keyboard input.
Waiting some more minutes, it will go to the promise raid screen and sit forever looking for devices. However, the cap/numlock now light when pressed so the keyboard seems to be responding (cnt-alt-del also works at this point, it doesn't before it).
I've tried disconnecting/removing all but the CPU/memory - same result. I tried an older graphic card from another machine - same result. I tried clearing the CMOS - same result.
Is the motherboard defective?
Thanks in advance.
Wayne
