MSI K9ND Speedster BIOS Flash gone wrong
Mabrito
I have a MSI K9ND dual socket F motherboard I use for my ESXi box. I went to go flash the BIOS yesterday as the version on it was from 2007 and it was misreading my processor temp for CPU0. Also, hoping there be an option that will allow the damn thing to boot without a keyboard attached.
Anyway, there were 5 BIOS versions greater than mine and they need to be done incrementally. Well, I flash the first version on it with success and it even booted up faster so all is looking good right? Well flash the second version and now it wont boot up at all. It just sits at the screen that checks the memory and allows you to push F2 to boot into setup which it does not. Not only that, it takes forever to check the memory (10 minutes compared to 30 seconds).
So does anyone know how the BIOS recovery jumper work on MSI motherboards. I know I need to set it to recover mode and its suppose to boot off a floppy of a BIOS file or something. If anyone has any advice to possibly fix this issue that doesnt involve getting a new motherboard, im open to suggestions.
Sorry for your luck mate....That's strange that you have to update incrementally...I don't onw any MSI mainboards but every other mainboard I've ever had could update directly to the most recent version....including the imfamous ECS & PCChips....*puke*
