hardwarephreak
- Jul 13, 2002
Just wanted to keep people informed of an issue that we have spotted with our Test/Eval AM2 system. It utilizes the MSI K9N SLI Platinum motherboard. We have seen issues with the system just shutting down during writing of a DVD. And I am not talking BSOD or random reboot, the sucker shutsdown, and the power LED flashes a few times and it is sitting there with a coaster in the Optical Drive tray. Initially we thought power supply, however, what we have found out is that apparently the BIOS on this board auto-negotiates the wrong speed (DMA/PIO) when using an 80-pin cable. If you use a standard 40-pin cable, it forces the slower speed, and system stability during writing is restored. We haven't done much other than to confirm the problem, and confirm the workaround is a definite fix. I am contacting MSI through the reseller channel to see if I can get ahold of a beta BIOS. But just thought I would post this, as most people post problems, and even when they find a solution it almost never gets posted.
I seem to remember this coming up with the Supermicro H8DCE board in one of the BIOS revisions, so I am wondering if it is something BIOS programmers need to be aware of when programming BIOSes for nvidia chipsets.
EDIT: There also seems to be quite a few people over in the MSI forums that are having the same issues, and they have posted the same solution as above as a workaround/fix.
